kieran.s gt
Member-
17 -
About kieran.s gt
- Birthday 03/14/1991
Website URL
http://
cork ,ireland
kieran.s gt's Achievements
im using aircon fan works fine i used a bracket and these to hold the fan http://www.ebay.co.u...=item45fb1f532a
Very tidy love the engine bay
Always like this gt looks so clean
Looks good well done
pour some oil into it and see if it spins free
Part number for ST185 pad fitting kit
kieran.s gt replied to BoGlE's topic in Specific Images & Part Numbers
tried toyota ? http://www.toyodiy.com/parts/p_J_1992_TOYO...BLMVZ_4705.html -
Blitz single SBC and boost dropping at 5k revs
kieran.s gt replied to TurboTom's topic in Intake, Turbo & Exhaust
Run a hose from turbo to actuator that will by pass boost controller and see if it holds boost better. -
have to have both washers on to seal it
only way to know for sure is count the number of splines on your own cv joint
cheers lads haven't got figure yet but I should be going on the dyno soon for some tweaks.
what thread size for oil sandwhich plate
kieran.s gt replied to mark-tozer's topic in MOT & Maintenance
3/4 unf -
copied thread from tgtt too long to start agian lol first mod was a set of 16 inch alloys and a good clean up As the weeks went on added few more bits and pieces hks turbo timer hks actuator set hks dump valve boost gauge ngk leads and plugs sps short shifter jasma exhaust pipercross induction kit koni adjustables with 40 mm springs -------------------------------------------------------------------------------- update 29/09/08 rx7 tmic fitted and resprayed with rockercover in silver oil catch tank and sps decat added megane splitter to front bumper update 26/12/08 wanted to change look a little so got myself an autobahnn fmic ,toms side skirs and optional rear spats here some pics hope you like update 15-2-09 got japspeed exhaust from Dave few weeks back and sps mild steel manifold from Dane made a nice difference to how the car goes and great sounding exhaust here is a few pics mani fitted and tuning developments throttle body pulley update 13/03/09 picked up a pair of omp seats today to along with earthing kit and one of nicks fuel pumps here is a pic of the seats should have them fitted at weekend hopefully fuel pump picture of the seats fitted update 25/05/09 relocated the autobahn piping to make it shorter painted calipers red mani heatwraped and jam ecu jam ecu as it stands now _____ update 21-7-09 well havent updated in a while noticed it has been down in power in the last while now i know why found a large hole in the decat l so got to get that welded for the mean time probably replace it later on Gt spec hybrid should be here mid week hopefully and decided going to give it a full service and add a few more bits parts to fit this week gt spec hybrid sps braided oil feed new dizzy cap/rotor arm fuel filter new gaskets ngk plugs heat range 7 oil temp gauge/pressure and fitting kit should hopefully have it all fitted for this weekend 24-7-09 got the hybrid fitted today and added a few bits next is to get a decent boost controller and handling/brakes and we should be good 22-09-09 got a zisco decat as my sps was beyond repair decat heatwrapped about time I added some handling/braking mods to the list whiteline rear arb whiteline anti lift kit 3 g front disks yellowstuff pads earls braided lines more bits added powerflex engine mounts cusco lower arm bar blitz dsbc id innovate wideband bride seat rail omp harness mocal oil cooler ep style grille and reverse scoop Toms bumper,ep styling grille and reverse scoop fitted (Update) sold the hybrid and wanted more power so i went td04 which includes zisco external wastegate manifold zisco downpipe zisco external wastegate with screamer pipe zisco oil and water lines all fitted spent the day cleaning the car and added a set of clear indicators after a few runs with standard clutch it went in bits so got exedy paddle to replace it engine bay Update 14/11/10 Decided to change the alloys so i went for a set of 15 inch rota slipstreams Have to say it handles much better on 15 inch wheels. update 8/2/11 Got a set of meister r coilovers and whiteline panhard rod. Fitted on the car still some tweaks to be done but here itis at the moment update 24/4/11 Bought alot of parts over the last few weeks omp deep dish wheel triple pillar pod st165 twin pot brake kit livesports rear lip and toms adjustable spoiler to finish the outside Thanks to focus mad for the great pictures Popsy decided to sell the parts from his car so I bought his forged engine ,emanage ultimate ,injectors,and civic Rad. forged engine 29/4/11 sprayed oil cooler,inlet manifold ,rad bracket & engine mount in metallic blue. sump and gearbox painted update 10/5/11 Engine painted and back in spec forged 4e greddy emanage ultimate 550cc injectors hks ssqv japspeeed exhaust system 15 inch rota slipstreams[ [Meister r coilovers oil catch tank ngk leads custom made short shifter with trd gear knob omp seats omp deep dish steering wheel omp 3 point harness Triple Gauge pillar pod tinted windows apexi air filter relocated to front autobahnn fmic toms front bumper toms side skirts toms adjustable spoiler Livesports rear lip autobahn rad hoses prosport boost gauge, oil pressure gauge, oil temp, and water temp red earthing kit t.d throttle body pulley braided clutch hose exedy paddle clutch tuning developments uprated fuel pump emanage ultimate st165 twin pot brakes earls brake lines whiteline rear arb whiteline alk powerflex engine mounts cusco lower arm bar blitz dsbc id Aem wideband bride d/s seat rail mocal oil cooler with thermostat ep style grille reverse scoop clear indicators j.d cooling panel vf48 mapped at 1.6 bar zisco externall wastegate manifold heat wrapped zisco downpipe heat wrapped zisco externall wastegate with screamer pipe zisco oil and water lines civic radiator and fan Whiteline panhard rod
3/4unf
