yes it does just slot in. as i said, use a longish bar with a flat end, and bar it VERY quickly to shock it. it will pop straight out. wheel hub side is a different kettle of fish. spend about half hour on it and if it dont move then it is never gonna come out. so you will have to undo the ball joint, track rod and hub carrier bolts and remove the shaft with the whole hub attached.
