tez
    129
    Leicestershire
tez's Achievements
  1. check out some of my glanza bits white mirror door handle turbo need rebuild spoiler very cheap http://www.ebay.co.uk/sch/carrj05/m.html?hash=item27c82b898e&item=170862021006&pt=UK_CarsParts_Vehicles_CarParts_SM&rt=nc&_trksid=p4340.l2562
  2. 1p for ct9 hybrid and glanza clocks links http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=170785850657 http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=170785844108
  3. watched it earlier. was good! few funny bits. shame the whole cinema was laughing as loud as goats in a field though.
  4. have you turned the actuator down?
  5. it will throw up fuel cut on standard ecu at 1 bar. lol have you got a boost gauge? stick jam on and what reading is the gauge giving at 3k(full boost)?? Is that in all gears??? my jam ecu(which im now selling) wink fitted mine with no problems like yours. (my is manual transmission) who did you buy the ecu from? did they run it on there car for a while ??
  6. stock actuator was on the car when i bought it and was boosting fine....
  7. baileys dump valve lol
  8. put my glanza back to nearly enough standard engine. cat front mount intercooler air filter normal position. standard ecu ported manifold no boost restriction(completely removed, no solenoids. In second gear I carnt get the 3 boost lights to come on. i can get two. My actuator has the vac hose from top to turbo and the spare line from actuator that is supposed to go to the boost solenoid. is left open. (nothing blocking it off. the standard dump valve(recirc thingy) i have no lines attached to this. as i have a DV and a breather filter on rocker. any ideas?? cheers im getting around 0.5 bar on my boost gauge/maybe 0.6
  9. thought the AT ecus where different to the MT ecus? i maybe wrong though!
  10. ive got a braided oil feed from race tech for sale? and a HKS adjustable actuator. cheers
  11. thanks lads! yea the spring on the baileys is pants! only need slight hand on the throttle cable and can see the spring in and out! its probably leaking to be honest! Id be happy with 250/300! Had a full polish & clay other day. MINT! need to get some pics up! Plans for tomorrow. 1) fit interior back in 2) remove coilovers and deflectors(selling them) another thing on the wind deflectors( they dont let hardly any air in the car, so im windows down, literally on fire when driving. General Clean over engine bay! due to the coolant Also had issues with the fog lights coming on with full beam! mid job(got that sorted) Dont want to be one of them twats with his fogs on, when it isnt foggy! also fixed the sideskirt as was hanging off(not perfect, but better)
  12. Update on this! Got insured,tax all legal other week. Car is doing well!(touchwood) lol Had a few hiccups. Had a water leak in which put coolant all over my engine lol(orange coolant ftl) part from that good! Really good! Fun to drive. But ive noticed a few things. Firstly motorway driving. Its horrible. sitting at 60/70 i only need to touch the pedal(a MM) and it wants to come on boost guessing i should stick my EFI pipe back on if i wanted to do more motorway? Due to my work i have to do the lovely drive to manchester now and then(once a month) The interior will be going back in! and a new backbox rubber as mine is snapped!(weird) What sort of mileage you lot getting to a tank? Also seem to always here my BOV wooshing on the motorway too! Cheers
  13. if you carnt hack the banta dont drink the fanta fella
  14. looks good! my rubber decided to just shit itself too. where u get a new rubber from?
  15. as above its all around the battery area and inlet area, where thermo is. The water temp didnt rise. and nor did engine temp. car was fine no problems. I didnt even notice it. till just popped bonnet. what could this be? ive just noticed that one of the turbo water lines(silicone hose) hasnt got a p clip on the end could this be the cause? the pipe heating up causing it to spray out the hose end and move around engine when moving? cheers.
