toymotaadam
    14
toymotaadam's Achievements
  1. Looking for piston number 2 for 4efte engine
  2. I don't think it will solve the high idle but it may just need cycle with the radiator water
  3. There plug you removed for the air con near the righ hand side head lamp you need to bridge it .grey plug
  4. Hi, all just curious to what these are worth.I made these kits as back ups in case anything happened to the ones i made originally 7 years ago as they where pretty hard to get hold of back then. They have been sat in my shed ever since as the original ones i made are still in tip top condition no snaps ect. The custom pillar pods was fully built by me. The GT is not stuck on it i apart of the pod. i did sell a few all going to malta from what i can remember not more than 6 was made ,i also made a screw fitting so can be fitted and removed easy. I will be finishing everything i have off and they will be up for sale as they are just doing nothing sat in my shed.
  5. Ep82 optional extra aero kit
  6. I got mine out of a corolla from scrap yard they give me them for free.
  7. Hi just stumbled across your question .Does it only start flicking when fully warmed up ? Some will say it your oil pump failing. What I recommend is to change your oil pressure switch located at the Front of the block right side of the cat 2 minute job.I do not recommend you drive the car until it has been change.it a Bit of a pain to get at with a spanner I snapped the plug of and used a socket.this will cure your problem.owner of 1995 Ep82 for 8 years
  8. toymotaadam
    ep82 piston
    looking for starlet gt ep82 standard piston with marking stamp 1 with letter b at the bottom
  9. Drivers side window regulator , I do not need the motor just the arms
  10. Do you have drivers side window regulator ?
  11. toymotaadam
    fcd
    in need of a fuel cut defender ,cash waiting
  12. is the HKS fcd still available ?
  13. i'll take the passenger window switch and cover if available
  14. just been reading on the forum if u are getting a repaint i recommend this before any polish ect ect http://cgi.ebay.co.uk/SUPAGARD-STANDARD-VE...=item20af9d9e83 this stuff has 3 years protection and it really does work this is what dealership's use on new car to keep them shiny on the forcourt this stuff was 50 pound for a sponge with polish inside when i got it so it rather cheap these days. all you do is pierce the sponge and wash your car . i got 2 cars out of mine . . i would have to say i would'nt use compound on any new paint work if you are only waxing it . if you keep rubbing compound in the same place eventually u will go through your paint work that's what it is made for to the cut the top layer of laquer away . id use a 3m finesse /glaze polish or farecla liquid wax which i like the smell of tbh you only need very small amount to go a long way . also supagaurd repells water so your car wont be wet when it raining ;) i used to work at halliwell jones bmw and believe me they are the most fussy place i have ever know use spend 7 hours buffing x5 bonnets .1 hell of a body shop tho £350 just to paint a bumper no repair just paint shocking prices ;)
