neilgt
    20
    South Wales
neilgt's Achievements
  1. If it had white deep dish wheels that would be me
  2. neilgt
    Ep82 indicator
    N/S front ep82 indicator and bulb housing required. Can anyone help
  3. Alright Marc hows things mate? long time no see
  4. Il be up for a meet after christmas
  5. Had to do the same with mine
  6. Have you got both rear calipers in working order. If so how much with postage to Dorset?
  7. You can try
  8. Yes disconnect the flex pipe and clamp if poss, and were the handbrake cable goes on the caliper there's a little clip that goes through a pin remove both of them then just unbolt. That is how they are on my ep82 hope that will help you
  9. 42 Vehicle speed sensor (VSS) No speed sensor signal to ECU when loaded driving condition with engine speeds 2000 to 5000 rpm. For 8 seconds or more. ECU Found this doing a search for ECU Diagnostic Codes on the forum
  10. I would Rob if I had the spare cash
  11. Ive got D1 nuts with my rotas, and even they can twist and bend out of shape if you don't keep the socket perfectly in line
  12. Gillingham performance centre 01747 825949. Tyler is a good lad there
  13. Ive got rota cup's 16x8j et35 with 195/45 and arches needed rolling
