Omar
    23
About Omar
  • Birthday 02/27/1986
    Barbados
Omar's Achievements
  1. My front Ksports are leaking, but I dont want to buy the Ksport replacement struts as I believe they will burst again. So my question is, has anyone tried to replace the strut with another brand like Koni? Or has any replaced the seals and rebuilt the strut?
  2. Where did you get the calipers and disc from? Thanks Omar
  3. Hi Guys and Girls, I have a 4efte when driving normally or hard, the RPMs sometimes does not drop back down to the idle position. It feels and sounds as though the gas pedal is stuck. It sticks anywhere between 2000 to 5000. When this happens I apply the brakes and put the gear in neutral but the RPM still remain stuck for another 3-7 seconds. It is a very annoying feeling when I am driving but it is very scary knowing this randomly happens especially with my girlfriend drives my car with my daughter as well. When I start the car in the morning it revs at 2000 or 2100 for around 3-5 mins then it drops down the set idle rpm. (Just adding this information as it may help) Any suggestions to fix this very dangerous problem? Thanks Omar
  4. I am looking to get a Garrett GT28 in the near future with a Link or Microtech ECU. The ECU and dyno is for the ACIS or Equal Length? If the ACIS, yes I know that some in dyno would be required to get the best out of it. , I am in Barbados. But I know now which one you would go for.
  5. Hi Guys, I have both an equal length intake manifold (ELIM) and an ACIS manifold (with all the required accessories). I am trying to decide which one manifold to use. I have seen some of the benefits of the ACIS from reading Hoodey's website but I dont want to count out the ELIM. Any feedback from persons would have used either of the two? Note I am still running a standard CT9 with the standard computer and I have access to a VTEC controller to switch the solenoid. But I will upgrading in the very near future.
  6. How much for handbrake cables shipped to Barbados?
  7. How much for handbrake cables shipped to Barbados? Thanks
  8. Hi Guys, I just want to know what size drill bit (I hope you guys in england call it that) do I need for drilling the hole when installing the bracket and the bolt to the under carriage of the car for the whiteline fixed RARB?
  9. Did anyone use a Hallman Manual Boost Controller? I was thinking of getting a MBC but from what you guys are saying an adjustable actuator is better for the cheap route but the EBC is best.
  10. This is the method I will be using this weekend for if everything goes according to plan. I hope this helps.
  11. That is absolute funny. I wonder what happened to him in the past.
  12. Check PM.
  13. Thanks for the information, trust me it is big help as I am looking to get one over the next couple of weeks. The EVO look great, I have always loved that shape EVO. Good luck with both builds.
  14. Great Result Tom with the awesome list of parts and I am loving the all black. One question, why did you chose the Gizzmo MS2 over the usual suspects (Blitz, HKS, Greddy)? How is it in action? I have a gizzmo dual stage shift light; it is awesome and one of my favourite things on my car. Its set up is just different from any shift light that I seen and the LEDs are the brightest. I was thinking about getting the boost controller (MS-IBC or MS2) but I wanted some real people reviews. Thanks Omar
  15. Do you still have the leads in the pic?
