bumblebee
    14
bumblebee's Achievements
  1. hey, what's the offset on these and are you wiilling to ship them?
  2. whats the price for the shell?
  3. depends on what you gonna do. If it s just a rebuild: Toyota/OEM Full Engine Overhaul kit Water Pump Oil Pump Toyota/ACL Bearing Set (Mains, Conrods and Thrust Washers) ARP Headbolt set Ugraded/Performance Clutch Not sure if i missed anything but if you gonna do a rebuild i think this list covers the stuff that you should get.
  4. incorrect wiring maybe? I'll check it over just to be sure.
  5. what year is your car?
  6. depends on what model EP82... since the MK1's lower control arm bushings have a different diameter.. later model GT's are the same as the EP91's if am correct...89-92 starlets- have a bushing diameter of 31mm O.D while the later models are 34 mm O.D it may be the other way around but...you get the idea
  7. would these lights also work in the dash? Thanks
  8. well, you can sell me...i am in St. Vincent
  9. Aidan @ EP-Syling on TGTT sell them..150 euro
  10. What width? am trying to match it with the table
  11. From the Powerflex Catalogue, it looks like No. 5 and No. 9
  12. well..you can try adding using the Barcode
