mrsilly
    44
1422 profile views
mrsilly's Achievements
  1. Selling my JAM ECU over on ebay: http://www.ebay.co.uk/itm/231971962621 Works on manuals too! Bought off of someone on here a fair while ago. My third cyclinder ring gave up so i gave the car away and kept this, never got round to buying another one, time to let someone else enjoy it.
  2. Quick update anyone who needs a replacement should get the one from Aaron radiators in the first post, it's the same size rad as the original.
  3. I'll take the BOV if Lilmiss doesn't.
  4. I've had this problem for a while. I was down seeing a mate at the weekend and mentioned it to him, he said to connect the rocker cover breather back to the air intake to reduce the pressure (i currently have a breather filter on my rocker cover). I haven't had time to try it yet but will give it a bash this week.
  5. I was at this stage a month ago but decided to sort it out for myself as no garage (it's been to 5) seemed able to fix the slow pick up. So yesterday I started. I found the slow pickup fault within 10 mins, there was an inch of takeup before the throttle started to open and it never opened fully because of this. Adjusted it and took it for a spin, it was quite a different drive I got back, ripped out the aircon, removed the turbo, fitted racetech manifold with all new gaskets, put my hybrid turbo on that's I had repaired four months ago, front mounted the intake, changed a few hoses, put it all back together and it worked! However I nearly soiled my trousers at 0.6 bar when the turbo came on full so I drove back home. Will check everything is tight this morning, plumb my EBC back in and go for another drive. Well pleased with myself. The Mrs isn't!
  6. Annoying as i was in Croydon yesterday. Don't need the fan, is it definately from an auto?
  7. Ok, so the Aaronradiator one is 27mm thick compared to camskills EP82 Turbo auto one which is 17mm I'd buy the Toyota OEM one if anyone has one new.
  8. Hi, can anyone point me in the direction of where to buy a radiator for an automatic V please? Here's what i can find: http://www.thecarparts.co.uk/acatalog/Radi...__1_3_2364.html http://camskill.co.uk/products.php?plid=m19b0s1301p61913 http://www.aaronradiator.co.uk/products/Ra...-8380-1689.html http://cgi.ebay.co.uk/TOYOTA-PASEO-1-5-16V...=item2562f54cfc The Toyota part number is: 16400-11760 google gives nothing! Are any of the above a solution? Thanks Mark
  9. One thing to do before buying is check insurance costs!
  10. It's the website control panel, at the top of the menu bar on the left hand side of the site.
  11. Check the you have Standard Editor selected in 'My Control Panel' > 'Board Settings'
  12. The EPROM will not erase just by opening it. They are UV erasable but most have stickers over the windows (on the photos I've seen of them opened) and my eraser takes 20mins to blank one, I'd guess that would be equivalent to leaving it in the sun for a couple of weeks. You'll be fine just to pop it open to find what's rattling. If you feel like it could you put a sticker over the window and take a photo for me?
  13. Cheers guys, i'll take another look tomorrow and if it doesn't snag on the gearbox i'll take a chance. It's a Tongs CT9, the basic one with the bigger ported internal waste gate.
  14. Last year i bought a Zisco ss decat from someone on here, I jacked the car up yesterday to fit it and noticed that there is nowhere to attach the brace. Looked on the Zisco website and it says not for auto next to it. My question is, how important is the brace? Has anyone modified the brace to fit an auto? Does anyone make a decat specifically for an auto? Thanks Mark
  15. mrsilly
    ECU HELP
    You cannot use a manual ECU on an Auto, it only works the other way round.
