mrkhan
Member-
Content Count
63 -
About mrkhan
Rank
- Birthday 07/01/1990
Website URL
http://
Manchester M19
ARC TMIC will be fine at 1bar. no messing around with dv's, pipe routes mounting or cutting bumpers.
Converting to 4E-FTE - Will I need to upgrade my N/A fuel pump?
mrkhan replied to Zeldoz's topic in Ignition & Fueling
poor fuel pump -
This car has been on sale for over a year and the price has budged only about £100. Still GLWTS n all that...
how do i turn the boost down on a ct9?
mrkhan replied to stuartwallace-ep91's topic in Intake, Turbo & Exhaust
I know its 15days late but you dont want to be guessing it really you want to find out the correct lengths and measuring it, otherwise you could do some damage. -
nearly done, MOT very shortly
bump for help, want it on the road now any luck finding a relay for me Enzo... the green relay says 'opening circuit relay' '85910- 10010' then '056700-9364' and it has 5 spade connectors at the bottom.
lol my younger brother seen this in levenshulme a few weeks ago and came home n told me about it, as excitable 13year olds do. wna see it in the flesh! its tidy man
the green relay says 'opening circuit relay' '85910- 10010' then '056700-9364' and it has 5 spade connectors at the bottom. the only thing caused by the shorting of the loom is the starting issue. the sidelights were working correctly at one point but when i got the dash and everything back in they changed their mind. the constant live to the wipers and indicators has been present since i did the conversion. i checked over the loom before putting it into the car and all seemed well, i removed the dash again yesterday in order to give the loom another once over and make sure everything is
No one able to help?
Hi again guys, not posted anything in a while, been busy with work and uni. I managed to get the engine in and the wiring done, the car was running and driving properly. just had to sort out a few electrical issues... some pics... anyways, since then the car went back into the garage so i could sort the electrics. In my attempt to 'sort' the electrics while very tired and frustrated, i accidentally plugged the power lead into the interior fuse box while the ignition was on, at this point i heard a pop and thought... "f*ck" since then the car will not start, i started by checking fuses
the awkward moment when you fail...
was reading your post about breaking your brake pipe earlier today. was wondering if you made it to castle combe or not. feel for you pal, schoolboy error with that pipe though! get the next project rolling!
Poly-Bushing your OEM Front ARB, what do you need?
mrkhan replied to Amjad's topic in Chassis & Suspension
just fitted mine today, nice and stiff, and supposed to be better than original ones. http://www.tm-developments.com/index.php?m...products_id=497 ours are different because we have ep82 arb's. (assuming amjads talking about his na, otherwise my theory goes out the window) theres 2different types of oem arb's neways. -
1- undo screw 2- pull
