RedlineShifter
    45
About RedlineShifter
  • Birthday 07/08/1992
  • MSN
    varunhrt@live.com
    Auckland, New Zealand
RedlineShifter's Achievements
  1. Yes, the items are brand new. The BCs are only about 2 weeks old. Any suggestions on how to corner weight the car? So the panhard rod does make a difference?
  2. Here is mine..
  3. Hey guys, I don't know if this has been brought up or not on this forum but I seem to have a problem with uneven ride height. When I had lowering springs, it seemed fine. However, when I installed D2 coilovers I noticed the ride height on the passenger side (right hand drive EP91) was slightly higher than the drivers side. When the D2s crapped out on me, I changed to BCs, but same issue. I tried doing a little research and found these two links over at TGTT http://www.toyotagtturbo.com/forums/archive/index.php/t-65886.html http://www.toyotagtturbo.com/forums/showthread.php?2493-What-is-a-Panhard-Rod According to those, having an adjustable panhard rod should fix this issue? Is there anyone else who has had this issue? Any help is much appreciated. Thanks, V PS - I'll try and get some pictures up ASAP. Its pouring like a b*tch right now.
  4. Hey guys, just need some advice on why my car isn't starting. I can hear the injectors going but it doesn't sound like its pumping fuel. Best way to describe it is when you put the key onto ignition, the injector doesn't put fuel through. I have a kill switch for the fuel pump but I've tried starting the car with the switch on off and on, but still no luck. It's also not cranking. Any help is much appreciated. Thanks, V
  5. Hey guys, I just need two things done 1. Bosozoku style exhaust (not extreme! Something like this http://cdn.speedhunt...sileightySH.jpg) 2. Lower the Starlet Thanks! Heres the pic..
  6. Hey guys, im just wondering if I need to drain the gearbox oil when I change my clutch? Also, what would be a quick way of fixing a stiff gear stick? Thanks, - Varun
  7. This is 1920x1080p if anyone wants to use it as a wallpaper
  8. Thanks for the replies guys. I'll try loosening it when semester break starts. I've already bent two C-Spanners trying! Lol
  9. The bottom locking nut wont move. I think it is too tight, is there a way to loosen it?
  10. Achilles ATR Sport I've seen many Achilles brand tyres on most of the cars in Hardparks. Im guessing they're alright?
  11. Hey guys Is a there a how2 on how to raise D2 Coilovers? Sorry if this has been brought up before, i just need to raise my glanza asap Thanks!!
  12. Hyper fits 195/50 on these rims in their deals. Would that mean its a safe enough stretch?
  13. What the hell, that sucks. Im running 195/50, you think they'll cert that? They're yours Just send me $800 NZD
  14. Why? I want to cert my car with these.. did he say why or what was wrong?
  15. Have you still got these mate?
