chrislucas121
    28
chrislucas121's Achievements
  1. hello what size is the 1995 gt turbo sump plug M12 x 1.25mm M12 x 1.5mm M14 x 1.5mm M20 x 1.5mm
  2. Hi i am running on a wastegate and i need a gasket! Now if im right it sits out side that ring of metal ypu can remove, abd its 44mm 45 mm but cant find one and help has to be metal?? Ive tryed ebay but nothing only have 35mm and 50mm
  3. Yea well it runs off a waste gate but yea I know why does it hold in two gears n not. The rest?
  4. Hi my car has all of a sudden got boost creep, the first two gears holds the boost at 1.2 bar then the other 3 goes off the scale! I have a mbc and in plumbed it and went off the wastgate and it was a constent 0.6 bar then I use the boost controller and it fucks up! Any help?? I have looked for leeks and nothing the only thing I can think is the wastegate don't work under pressure, I am getting a ebc when I get paid but any help??
  5. Count me in I've been twice now amazing show
  6. Apparently its in a chase in the Kent area at the moment!
  7. Hi I have a 1995 gt Turbo advance and I have a td04 kit, I fitted a civic Rad today and had to move my waste gate I noticed that what looks like the old actuator had been welded on, but was loose so weled it on again and now I have loads of boost, and early like 2000rp.m. any help please??
  8. Have just fitted a famed kit on the group buys and it helps through the gears but it struggles to start now I have to give it some gas to start it I didn't before, if I don't it will turn over then stop any help please??
  9. I have the same prob on my ep82 :-(
  10. Hi I have a 95 gt Turbo is it worth putting throttle bodies on it? What would be the gain?
  11. Hi I was looking for some help I have a imported gt Turbo 1995 gt, and when I got it my boost gauge zsaid I had 1.1 bar, now for some reson its on going up too 0.7-8 what can be the Couse of that??
  12. Hi I have changed the bareing in my ep82 and now the pin keeps slipping and makes the hub nut lose any help???
  13. Hi where do you put the oil in the gear box and how much? Its on a 1995 gt Turbo import
  14. No that's not my problem I don't have a wire going to it full stop! I need to know where it goes too
  15. Ok do you you where it leads to tho? And is it the back qauter panel I have to remove?
