Hawaiiviper
    129
About Hawaiiviper
  • Birthday January 22
    Mildenhall
Hawaiiviper's Achievements
  1. I've had a speedvision turbo at 1 bar for about 5 yrs and it still pulls hard...no issues
  2. ^^^^^morgey said it all I'm american and its 25 yrs from production month and year i can take it to the states. I would be one of the few starlet owners in the states
  3. do you know what was the production month? just wondering if i were to buy has to be 25 yrs old in sept 2015
  4. It is a 97 Glanza and has the following: Hybrid Ct9 from speedvisioncps 330CC injectors Warlboro 255 kph fuel pump sard pressure regulator Apexi Power FC (no commander just computer) Mild Steel Manifold Sard performance down pipe/cat convert Fujitsubo cat-back exhaust speedvisioncps FMIC Exedy Street Clutch w/cusco lightweight flywheel Cusco 1 way LSD All bushings except motor mounts have been replaced by trd bushings Lighweight cam gear Tein coilovers and have a spare used set of tein's Cusco front upper sway bar & C pillar bar (no brand) Defi Link BF series gauges (boost. oil temp, water temp, oil press, exhaust temp and racing tach....all light up blue) Greddy boost controller MOMO steering wheel trd shift knob Recaro front seats with drivers 4 point seat belt Slotted front disks with Project Mu pads and Project Mu braided brake lines. RPF-1 15" 7J (black) wrapped in Potenza RE-11's...Also have spare set of 16" rims Mettallic black with extra metallic flake painted in 2012 in japan and is a sun roof model Pretty wicked sound system but will probably remove it. Yellow top optima battery but might be removed because was meant for sound system HID 6K headlights and HID 3K fog lights After market doppler affect horn w/ switch (from japan and might not include) Silk road engine dampener NGK iridium plugs ngk wires aftermarket koto radiator with slimline fans Also have a handful of spare parts.
  5. How much were you looking to get for it. have a ep91 in mildenhall area and i will be looking to sell this car eventually as I'm leaving the country late 2015
  6. maybe one of your injectors is leaking?? happened to me the oring was bad
  7. Project Mu are usually turquoise colored yes PMU is short for that. I can check the garage and get you a part number if that helps.
  8. Additionally their pads are awesome
  9. Is their a way for any of our vendors to source PMU pads from japan? I know they still make pads as I was in japan last year and ordered some while I was there. But would be nice if I didnt have to fly across the world to do it.
  10. Paul if you ever need hook ups I can order from tirerack.com and shipping is fast and prices are in us dollars
  11. If you can spare 4000 id sell you my glanza and it's in a lot better condition and has a lot more mods
  12. i bought a hybrid ct9, manifold, front mount, injectors, radiator fan fuel pressure regulator, fuel pump and no problems. I have a stateside address in the U.K. so shipping is very cheap
