Charlie28 Posted March 15, 2016 Posted March 15, 2016 Removed the master cylinder after cross threading it when installing my abs removal kit from TD. I've replaced the master cylinder and everything is connected up. Should i have bled the master cylinder first before fitting? Or will bleeding the brakes normally remove any air trapped in the system? Quote
StuDoc 72 Posted March 15, 2016 Posted March 15, 2016 You just bleed the brakes as normal. Open the bleed nipples at each corner and drain the fluid out first though so you have all new fluid right through. Quote
Charlie28 Posted March 16, 2016 Author Posted March 16, 2016 You just bleed the brakes as normal. Open the bleed nipples at each corner and drain the fluid out first though so you have all new fluid right through. I done this at the weekend bud. Done all 4 corners and got fresh fluid coming through with no air but the peddle just went straight to the floor. Quote
Ollieh17 Posted March 16, 2016 Posted March 16, 2016 Did you replace the gasket on the m/c? I took mine off and fitted and the abs removal too and had no issues. Quote
Charlie28 Posted March 16, 2016 Author Posted March 16, 2016 Did you replace the gasket on the m/c? I took mine off and fitted and the abs removal too and had no issues. I didn't replace the gasket bud no, it was abit shagged too! But that wouldn't allow air into the braking system would it? Quote
Ollieh17 Posted March 16, 2016 Posted March 16, 2016 Not sure tbh worth replacing though i suppose. They are the same as a yaris Quote
Charlie28 Posted March 16, 2016 Author Posted March 16, 2016 (edited) Which caliper did you bleed first? I started with the right rear (if looking at the car front on) then moved over to the left hand side, but i had trouble getting any fluid out from there so I then bled the front and went back to the right rear and over to the left again which seemed to solve that problem. But the pedal was just on the floor once i'd worked my way round the car (furthest away from the master cylinder first) Edited March 16, 2016 by Charlie28 Quote
Ollieh17 Posted March 16, 2016 Posted March 16, 2016 (edited) Standard brakes? Edited March 16, 2016 by Ollieh17 Quote
mccartney11 Posted March 16, 2016 Posted March 16, 2016 Do it with the car running to create a vacuum, then go again with it turned off Quote
StuDoc 72 Posted March 16, 2016 Posted March 16, 2016 Do it again passengers rear first then drivers rear then passengers front and finally osf Make sure your topping up the fluid after each corner and at the beginning just top it right up not just to the max line. If you have someone available (anyone will do) get them to sit in the car have them pump the brake pedal 3-4 times then hold it on while they hold it on undo the nipple, while they still hold it on close it again once all pressure (fluid and air) is released close it. Only once it is closed again can they let their foot up pump the pedal and repeat until clear air free clean liquid comes through. If you do this at all 4 corners I guarantee if there isnt a leak anywhere you will get a good pedal. Quote
Ollieh17 Posted March 16, 2016 Posted March 16, 2016 Buy a bleed kit from halfords, makes life so much easier Quote
Starlet__SR Posted March 16, 2016 Posted March 16, 2016 As above. Easi bleed works wonders. Don't over pressurise the bleed kit though. Quote
Charlie28 Posted March 16, 2016 Author Posted March 16, 2016 Do it again passengers rear first then drivers rear then passengers front and finally osf Make sure your topping up the fluid after each corner and at the beginning just top it right up not just to the max line. If you have someone available (anyone will do) get them to sit in the car have them pump the brake pedal 3-4 times then hold it on while they hold it on undo the nipple, while they still hold it on close it again once all pressure (fluid and air) is released close it. Only once it is closed again can they let their foot up pump the pedal and repeat until clear air free clean liquid comes through. If you do this at all 4 corners I guarantee if there isnt a leak anywhere you will get a good pedal. I had good fresh new fluid coming out of all corners with no air bubbles. I'll give it another shot this weekend. Quote
Flynn Posted April 9, 2016 Posted April 9, 2016 Sorry to go a bit off topic but is there a how too on fitting the abs delete kit as I'm pretty clueless? Quote
