Littleg Posted March 18, 2016 Posted March 18, 2016 Hi all....Bit of a odd one I have some white/blue smoke I'd say it's white but it could have a small tinge of blue coming out the exhaust It's quite thick I've tested the headgasket and that's fine I've checked the turbo and that's also fine I check the rings and pistons the have also come back fine Can't be the pvc as mine been taken out and still smokes The car it self runs a1 can't fault it at all just stumped to what could be the cause And info or recommendation would be really helpful many thanks Quote
Littleg Posted March 19, 2016 Author Posted March 19, 2016 I didn't think of that how can I test for that mate other than getting it on the wide band Quote
mccartney11 Posted March 19, 2016 Posted March 19, 2016 Check plugs see if they're whitish/very very light brown it's lean, is there water dripping from your exhaust when it's putting out smoke? Quote
Littleg Posted March 19, 2016 Author Posted March 19, 2016 I'll check the plugs a little later and will report back.... and yes there is a small drip from the exhaust every 5 seconds or so Quote
5e colin Posted March 19, 2016 Posted March 19, 2016 if it bothers you that much i would suggest to just turn the engine back of might be valvestem leaking oil cousing bleu pufs +rip of the turbo manifold and shine a light inside each exhaust port to see if you can spot seepige Quote
Littleg Posted March 19, 2016 Author Posted March 19, 2016 Thanks 5e Colin don't think valve steams as it dose it all the time but I will nip the manifold of and have a gander turbo seems gs no movement in or out or up n down side to side etc really scratching my head as passed a sniff test and comp test .....I have just checked the spark plugs 3 and 4 was perfect 1 and to were a white ish colour at the tips all were dry I did notice on 1st start up there was tiny tiny one spit of fluid pip out of the mainfold which might be condensation it's a ss mainfold and I'm de cat to if makes any difference at all Quote
Andytopps Posted March 20, 2016 Posted March 20, 2016 I would say the gaskets gone, but you said you checked that, or low in engine oil. or the wrong type of fuel, its trying to burn off. or you can check with this diagnostic software, just connect to your laptop and incar connector to test all engine faults and it will show up on laptop. see here. Quote
Littleg Posted March 20, 2016 Author Posted March 20, 2016 Andy I'm thinking headgasket even tho its past a sniff test if it is its a very minor leak I will try that programme get pal to download it and give it a ago fuel wise I'm running 99 Ron I've not tried a oil change yet but will next week when get paid Quote
5e colin Posted March 20, 2016 Posted March 20, 2016 I would say the gaskets gone, but you said you checked that, or low in engine oil. or the wrong type of fuel, its trying to burn off. or you can check with this diagnostic software, just connect to your laptop and incar connector to test all engine faults and it will show up on laptop. see here. any links to get free download ??? Quote
Ollieh17 Posted March 21, 2016 Posted March 21, 2016 How is a obd connector (if it even works on the starlet) going to tell you why there is blue smoke lol Quote
StuDoc 72 Posted March 21, 2016 Posted March 21, 2016 How is a obd connector (if it even works on the starlet) going to tell you why there is blue smoke lol Thinking this myself. Software wont do shit for you LMAO. Also you said you werent sure if it was the gasket but it past the sniff test? As in you sniffed the coolant for petrol? Its blue smoke therefore oil so your coolant would have nothing to do with it. Quote
Littleg Posted March 21, 2016 Author Posted March 21, 2016 Hi people just a update in the end I decided to take the head off and the results was deffo headgasket I've had skim and a new 1.2m uprated headgasket put in and all is well had 2 very small breaks in the head gasket one on the water way and one via a oil way ...... yh software deffo won't work for this lol thanks for all advice and help Quote
