H_D Posted March 23, 2016 Posted March 23, 2016 Looking at getting this triple core civic rad http://www.ebay.co.uk/itm/All-Aluminum-Radiator-56MM-3-Row-CORE-FITS-Honda-Civic-EG-EK-92-00-High-per-/271905213192?hash=item3f4ed04b08:g:UbAAAOSwnDZUBn5fJust wanted to know if they need any modifications to fit?Will my stock fan work with it?I am aware I will need a mounting kit.Seen some listed on trader websites priced 3-4 times higher so just looking at cheaper options. thanks Quote
StuDoc 72 Posted March 23, 2016 Posted March 23, 2016 You need to cut off one of the original rad mounts. Also pretty sure you dont want to use the original fan I think they shroud it too big and bulky. You can though use the a/c condenser fan ( with some modification ) if you still have it. All you need to do is remove the blades with the 3 bolts in the middle and drill out the centre, flip the fan over and it will now be a sucky fan and you can use it Quote
H_D Posted March 23, 2016 Author Posted March 23, 2016 You need to cut off one of the original rad mounts. Also pretty sure you dont want to use the original fan I think they shroud it too big and bulky. You can though use the a/c condenser fan ( with some modification ) if you still have it. All you need to do is remove the blades with the 3 bolts in the middle and drill out the centre, flip the fan over and it will now be a sucky fan and you can use it Thanks for the speedy reply Stu Quote
aleximport25 Posted March 23, 2016 Posted March 23, 2016 Or cheat and mount the fan on the front of the rad 😉 Quote
