So I changed my rubber hoses for braided ones
But now I have excessive brake pedal travel the brakes work but the pedal almost touches the floor before they work
I have bleed them about 10 times starting from furthest away and using clear pipe on the nipple to see any air coming out but it all seems good
Have also tried bleeding them with engine running but still no joy
Any ideas ?
You still have air in them mate. Do you have ABS? Then probably air in the unit and hard to remove. You just got to bleed until its all gone.
Nope it's ep82 none abs buddy , literally have bleed them so many times
Dad seems to think master cylinder but I'm not so sure
Deffinately still air in there if it was fine before.
Did you have 2 of you doing it and locking it off with pedal down before lifting again?
Did you make sure the reservoir was always above the minimum, they suck up air way befor they get anywhere empty. This happened when doing mine and had to go back round again!
Yea had two people doing it
Always kept the reservoir above minimum not unless like you said it's been sucking in air without me realising as I've just kept it above the market
