MR-2 Posted April 13, 2016 Posted April 13, 2016 How well that Glanza tank went, that was my first plan, but desided to keep old, free space low point space for exhaust silencer or future mods. Normal EP91 4E-FE tank is maybe identical to Glanza. Quote
dubeam Posted April 13, 2016 Author Posted April 13, 2016 Will do Pikey, thanks! @ MR-2,I bought this car with the tank already swapped in. happened to be my old glanza tank by coïncidence, lol.Can't tell you how difficult that was but seems very easy to do. only requires a little bit of cutting underneath the rear seat to fit the walbro in. If I need to take some pictures let me know, id be happy to help. Quote
MR-2 Posted April 13, 2016 Posted April 13, 2016 Yes, more project pictures So cool looking engine, I maybe do same kind of setup before turbo. Is electrics under work or what You have on battery corner now? Quote
dubeam Posted April 14, 2016 Author Posted April 14, 2016 Yep, did some tucking. Also I still had both ep70 and ep91 looms in, so I had to cut some out. Made a battery sleeve, painted my washer fluid box, installed my GPS track and trace (very accurate!) Installed my polished catch can, polished half size radiator and polish coolant tank. no time left to add the hoses, will leave that for next time. Quote
MR-2 Posted April 14, 2016 Posted April 14, 2016 So shiny, looks good. Catchcan tank for turbo setup or just for fun? Plenty of room to do things, no powersteering or aircon. Intresting radiator, so small outside, Honda radiator? That exhaust fits very nicely, is that by the way 4-2-1 or 4-1 header. Just tested one 4A-FE header, not so fast job to modify, maybe later, if have time. Quote
starletezy Posted April 14, 2016 Posted April 14, 2016 Very nice and clean mate! keep up the good work!! Quote
dubeam Posted April 14, 2016 Author Posted April 14, 2016 it's a 4a-fe header yes. Wasn't a fast job to modify but I had this done as I can't weld unfortunately Radiator for an ep82 as far as I know. Bought this thing before I even had the car these upgrades are meant for the turbo setup. Just kind of making the car turbo ready bit by bit.Very nice and clean mate! keep up the good work!!thanks mate! Quote
MR-2 Posted April 14, 2016 Posted April 14, 2016 Probably Honda radiator, never seen for Starlet straight. I'm gona do later own small custom, turbo systems first so can see how much room is left. Maybe even remounted turbo on top of gearbox. Quote
dubeam Posted April 15, 2016 Author Posted April 15, 2016 Could be, just finished the hoses and seems to work perfectly. fan is nice and quiet also. Sorry for the purplish pic, my phones camera is not okay Also verrrrrrrrrry lucky to find myself a cluster with tacho! really really happy with this one. plugged it in straight away but found out my lighting doesn't work and it won't show my rpm's so it needs some rewiring I think? Anyone has an idea? Quote
MR-2 Posted April 16, 2016 Posted April 16, 2016 Good catch that cluster, I help You later with electrics Quote
dubeam Posted April 16, 2016 Author Posted April 16, 2016 Thanks a bunch mate! I got the lighting figured out already, I followed the copper lining on the back of the cluster and noticed this cluster needs an extra mass. I added a wire in the second slot and the lighting worked! Just the tacho nos, no clue on this one lol. Quote
dubeam Posted April 17, 2016 Author Posted April 17, 2016 (edited) Got the tacho working also! Looks so much better now it's finished. For the people still wondering how to wire a ep70 tacho, I will explain this. You will have to add a wire from your negative on the coil to your cluster. You will need this black wire: You want to add it to another black wire on the cluster, this is its location: For the lighting I went to the scrapyard and got myself a second plug to use the pins inside of it. You have to add this wire to an empty slot in the existing plug and connect it to mass. the red wire was the only wire that was laying around at that time.. lol Edited April 17, 2016 by dubeam Quote
MR-2 Posted April 17, 2016 Posted April 17, 2016 Okay, I'm late with this. Same wire also added here to get it work I added it straight to ground, maybe I have to put it coil ground also, to get it work propely, thanks for the hint Quote
MR-2 Posted April 17, 2016 Posted April 17, 2016 Can´t add any pictures, weird problems going on "You are not allowed to use that image extension on this community." Quote
MR-2 Posted April 18, 2016 Posted April 18, 2016 Now Photobucket works again, and maybe mobilephone allows adding. Quote
MR-2 Posted April 18, 2016 Posted April 18, 2016 Blue to Brown wire is RPM signal in this gauge. Also extra ground needed...And photo ofcourse... Quote
Clinternational Posted May 12, 2016 Posted May 12, 2016 Again another hollander haha...Ziet er goed uit.... is dat een civic radiator ? Quote
N F X Posted August 18, 2016 Posted August 18, 2016 ok..nog een andere nederlander hier op t forum! Quote
