EP70-PT Posted April 3, 2016 Posted April 3, 2016 (edited) So since I removed my front bumper I noticed a major oil depot on the bottom/middle of the timing cover: Engine has 220k km on the clock Edited April 3, 2016 by EP70-PT Quote
Whitenoize Posted April 3, 2016 Posted April 3, 2016 You might be lucky mate that could just be a simple rocker gasket or possibly a cam shaft oil seal definitely looks like it's coming from the top half of the engine and running down Quote
EP70-PT Posted April 3, 2016 Author Posted April 3, 2016 I just changed the rocker gasket, have to remove the timing cover to check everything out Quote
Whitenoize Posted April 3, 2016 Posted April 3, 2016 I just changed the rocker gasket, have to remove the timing cover to check everything out was it a genuine Toyota gasket? Some of the others don't seal properly and leak at the back of the engine Quote
EP70-PT Posted April 3, 2016 Author Posted April 3, 2016 It was already like this, I changed it and the car is not moving since january so can't be the new gasket i think Quote
Walker96 Posted April 3, 2016 Posted April 3, 2016 It was already like this, I changed it and the car is not moving since january so can't be the new gasket i think I had this didn't just changed rocker gasket as well so didn't think it where that. But it was a cheap ebay one so I got a genuine toyota one and it's stopped. So might be that if you don't have genuine one. Quote
Whitenoize Posted April 3, 2016 Posted April 3, 2016 I had this didn't just changed rocker gasket as well so didn't think it where that. But it was a cheap ebay one so I got a genuine toyota one and it's stopped. So might be that if you don't have genuine one. I had the exact same problem with a crap gasket hard to tell from pictures but looks around the place Quote
Walker96 Posted April 3, 2016 Posted April 3, 2016 I had the exact same problem with a crap gasket hard to tell from pictures but looks around the place Yeah mine was a very cheap ebay one lol looks around the same places Quote
EP70-PT Posted April 4, 2016 Author Posted April 4, 2016 Will try then, will give it a degrease first, where can I get a good one + rocker cover nut seals? (The spark plug seals that came with it are good enough) Quote
EP70-PT Posted April 4, 2016 Author Posted April 4, 2016 Maybe from the old one? I have to take the engine out soon so will give it an overall Quote
