Head gasket size id/measuring.
Recently I've had to strip my forged engine to have the valve springs uprated (due to valve float/bounce) and ended up getting the whole thing freshened up as well. One problem with refreshing everything is I don't know what thickness the head gasket is (lost my records!). Measuring wise what's the best/most accurate way to measure these? Clamp with something and mic it?
I believe its an Athena gasket.
Can't see any numbers etc on it. Or have I maybe missed it? Or does the number of layers possibly dictate the thickness or would it be the same number of layers but each a different thickness?
If that makes any sense...
