Hi guys my cars been nothing but a headache recently. It's fine when until I boost it once then it starts hunting idle goes from 1.5k - 2k constantly then when I attempt to boost it feels like there's no spark top end of revs. Someone help me because it's starting to annoy me?!!
Thanks in advance
First thing I would do is Check for boost leaks in all hoses, then clean out the icv (idle control valve) and throttle body 👍🏻
Already checked for leaks. There was a hole in one of the vacuum pipes from boost solenoid to wg and I changed it. Still the same
Mine was doing the same, i would remove every vac line and then cover the hole with your finger until you find the one that is leaking. Sometimes unplugging the vac lines and starting the car, then re-fitting them sorts it as the ECU goes abit funny...
I'll give this a try when I can.. What ECU have u got mate?
This was on a standard ECU when i was running in my engine.
