Bug679 Posted May 18, 2016 Posted May 18, 2016 By the way you describe the problems your having and what ya have and haven't got then yes was waiting for a breaking Glanza post from ya next 😜 Quote
haggis Posted May 18, 2016 Author Posted May 18, 2016 well the issue with the low boost was due to air filter being hard uo againat pipe and not lettting air in.. all ive done is given it th air back. stock boost etc..just feels much better with the short route which is making me think the boost is creepin nowgonna order a gauge tomorrow as well para now haha Quote
patman Posted May 18, 2016 Posted May 18, 2016 Make sure you get a half decent boost gauge mate not these cheap ones of eBay, everyone's got different opinions here but personally I wouldn't even use boost until I worked out what's actually on the car and what needs changing etc, maybe I'm wrong here but was wondering what a jam ecu is doing on the car when everything is totally stock? Quote
haggis Posted May 18, 2016 Author Posted May 18, 2016 sound ! are those prosport LED ones any good ?bought the jam for future mods and i was hitting fuel cit after exhaust and decatstuff done so far:exhaust (custom)decatAc removedJAM ecushort route intakei know its not much so far but the ECU made a huge difference . car running much nicerwill get gauge ordered tomorrowthen still to come in next month or twoexhaust manifoldhks actuatorfuel pumpfront mount intercooleralso wanting to up boost to 0.85 after that gear on Quote
Bug679 Posted May 18, 2016 Posted May 18, 2016 Make sure you get a half decent boost gauge mate not these cheap ones of eBay, everyone's got different opinions here but personally I wouldn't even use boost until I worked out what's actually on the car and what needs changing etc, maybe I'm wrong here but was wondering what a jam ecu is doing on the car when everything is totally stock? Was thinking the same myself Pat. Would be over fuelling like a good one maybe ? Getting the AFRs would be a good call maybe would like to know though has me intrigued this post to say the least lol Quote
haggis Posted May 18, 2016 Author Posted May 18, 2016 yeh gonna get booked into for afr . i know im running rich it smells like it Quote
Bug679 Posted May 18, 2016 Posted May 18, 2016 If your running the JAM and all them other mods a lot of people recommend 1 bar boost but it's all hit and miss with p&p ecus get your AFR checked and it all should be good after that 👍🏻 Quote
haggis Posted May 18, 2016 Author Posted May 18, 2016 ok bud cheers for advice im still learning Quote
patman Posted May 18, 2016 Posted May 18, 2016 Don't worry mate about I know it's not much so far and your still learning, everyone has to start somewhere, I'm still learning and often ask for advice on here, always bugging 5e colin for help, and even ask bug679 in this thread for advice at times it's good to ask 👍🏻, bugs also right aswell with the afr that needs to be checked asap, can I ask haggis what is the jam ecu mapped to? Or did you just plug it in etc? Quote
patman Posted May 18, 2016 Posted May 18, 2016 I have a prosport boost gauge and they seem to do the job well there not the best but I think there spot on.Rspec.co.uk Quote
haggis Posted May 18, 2016 Author Posted May 18, 2016 nice one man ill order one of them. if i had the money id get everything now just a bit of an eager beeverthe JAM ecu is plug and play. removes fuel cut, increases RPM and adjust fueling so im led to belive. i also read that its fine to run them at stock boost as they have fuel settings that adjust depending on boost but it does recomend a fueling check... as far as im aware you cannot change the map as such, they are just a bit more aggressive than stock plus the other things mentioned. apparently JAM and various others did these ECU's for toyota demo cars etc originally ( key word being apparently ) cant belive everything your read i guess Quote
patman Posted May 19, 2016 Posted May 19, 2016 So first things first mate get it on a rolling road ASAP to check the fuelling then go from there 👍🏻 Quote
haggis Posted May 19, 2016 Author Posted May 19, 2016 cheers again . id be fooked without this forum and the people on it . gauge ordered and will get it book for fuelinf this week. i guess ill need an adjustable fuel pressure regulator if it turns out im lean or rich Quote
patman Posted May 19, 2016 Posted May 19, 2016 I would say yes mate to that although make sure you get a genuine one not a fake, it's always money money money with these things, I would definitely change the manifold too Quote
haggis Posted May 19, 2016 Author Posted May 19, 2016 roger that . boost gauge arriving tomorrow Quote
haggis Posted May 21, 2016 Author Posted May 21, 2016 fitted gauge today . looks well smart and looks like im running about 12 psi.gonna get wideband now Quote
patman Posted May 21, 2016 Posted May 21, 2016 12 psi is .8 bar I don't know what others would think but I would personally get it down to .6 bar with your set up mate Quote
haggis Posted May 21, 2016 Author Posted May 21, 2016 might get a cheap manual boost controller then to be safe until i can afford the extras Quote
patman Posted May 21, 2016 Posted May 21, 2016 Someone else will know this part just wondering why it's running .8 bar on a standard actuator too Quote
Whitenoize Posted May 21, 2016 Posted May 21, 2016 (edited) Standard high boost is around 0.65 bar. fuel cut comes in around 0.85 even small mods like de cat, fmic ,air filter relocation and exhaust will give boost creep you could either go external wg and get an ebc (expensive option) or get an adjustable actuator and a mbc or you can pick up a good second hand ebc for not very much money and take it up to 1 bar and get your afr,s checked Edited May 21, 2016 by Whitenoize Quote
haggis Posted May 21, 2016 Author Posted May 21, 2016 i reckon the air filter relocation letting in much more air in and decat allowing the spool cheers white thats the plan Quote
