Gearbox, clutch kit, flywheel off
Poke a hole in the seal
Put a screw in the hole and use a driver to pry against it to pop it out (so ya dont damage seal contact surface)
Clean up the area
Lube the new seal
Gently and evenly tap the new seal in (i use a 3/8" extension and a hammer)
Use new flywheel bolts or loctite the old ones
Rebuild in reverse order
Sorted.
Clean up the area
Lube the new seal
Sorted.
Lol fair enough.
So long as there is no special requirements getting the old one out ill be happy.
Well not happy but less annoyed doing a shitty job :)
