I've got a race spec rocker cover I'm fitting this weekend but i don't yet have a catch tank!
Am I able to run a bit of hose from the port on the rocker (where pcv was) back to the inlet as a temporary solution ?
Use a drinks can as a temporary catch can, you see some people using monster or redbull cans.
If you just put a hose from your rocker to the inlet, as soon as you boost it will be pressurising the crankcase
