Cattanach Posted May 20, 2016 Share Posted May 20, 2016 I've got a race spec rocker cover I'm fitting this weekend but i don't yet have a catch tank!Am I able to run a bit of hose from the port on the rocker (where pcv was) back to the inlet as a temporary solution ? Quote Link to post Share on other sites
5e colin Posted May 20, 2016 Share Posted May 20, 2016 just fit the rocker setup and lay the 2 an hoses in the bottom of a bottle cut a coke bottle top end off block the manifold nipple Quote Link to post Share on other sites
adzy Posted May 20, 2016 Share Posted May 20, 2016 Use a drinks can as a temporary catch can, you see some people using monster or redbull cans.If you just put a hose from your rocker to the inlet, as soon as you boost it will be pressurising the crankcase Quote Link to post Share on other sites
Cattanach Posted May 20, 2016 Author Share Posted May 20, 2016 Ah okay cheers guys That clears that up! Quote Link to post Share on other sites
