FlipGT1991 Posted May 20, 2016 Posted May 20, 2016 Any threads on rebuilding a 4efte head ? Can't seem to see any in the how to sections Quote
Phil Posted May 20, 2016 Posted May 20, 2016 There is nothing to it man. I'm no mechanic and I did my own. Just take it all apart and you'll see how it needs to go back together Need a couple of tools but nothing major. Watch a wee tutorial on lapping valves back.Greek fella Chris of tgtt has a full engine build set of videos on YouTube aswell which are worth a nosey Phil Quote
FlipGT1991 Posted May 20, 2016 Author Posted May 20, 2016 Yea just gonna do it myself and think I saw them? That the 12 part 4efte bottom end and head rebuild? Watched then all just wondered if anyone had done it and had any other advice. Cheers though mate ! Quote
maddox710 Posted May 20, 2016 Posted May 20, 2016 Just make sure you make a note of where each component came from Quote
FlipGT1991 Posted May 20, 2016 Author Posted May 20, 2016 Aye I will do mate. Any of use suggest getting new springs ? Just standard or is it not essential to do then ? Just head skimmed new seals etc Quote
AdamB Posted May 21, 2016 Posted May 21, 2016 It's always worthy of replacing springs as they sag and lose tension over time. But unless you're going to raise the rev limiter or put in different cams, I wouldn't worry and just use what came out. Quote
FlipGT1991 Posted May 21, 2016 Author Posted May 21, 2016 Tried looking springs online but could only find uprated ones which I'm not interested in spending 200 odd quid on. Id like to change them anyway just. Get standards from Toyota ? An no, no uprated cams or anything will be going in Quote
AdamB Posted May 21, 2016 Posted May 21, 2016 Just keep the ones that come out the head mate. Toyota will cost you more than aftermarket ones. Quote
gorganl2000 Posted May 23, 2016 Posted May 23, 2016 (edited) make sure you label the shims before you remove them....like in1, in2,etc...ex1, ex2, etc put them back in the exact spot you took them from when reassembling PS- remember to put the "tension/service bolt" into the cam before you remove it Edited May 23, 2016 by gorganl2000 Quote
FlipGT1991 Posted May 24, 2016 Author Posted May 24, 2016 Was just gonna set everything in tubs in the order they would be in the head and yea will do. Out a curiosity I got my head there at the weekend and had a look and the two dots on the cam gears were directly lined up but where the service bolt goes was sitting off so I couldn't get the bolt through ? Quote
Phil Posted May 24, 2016 Posted May 24, 2016 Can gear just not tensioned manEasy sorted when you hAve it apartPhil Quote
FlipGT1991 Posted May 24, 2016 Author Posted May 24, 2016 So do I just go ahead and remove the cams and sort it that way? Then put the bolt in once I have then lined ? Quote
