Was out having a little run around against a vw scirocco , was doin about 80 gear 4 just under 5000rpm and it felt like the engined jumped a bit, like it lagged? (felt this before but that was when i hit the restricted speed 120+) but carried on fine to 100??
Well you need either a plug and play ECU or a piggyback and get it mapped.
If your completely standard and hitting fuel cut then there is something wrong though. You sure the car is 100% standard
Yea as far as I know I've had her for the past six years and apart from the air filter and dump valve, I haven't added or changed anything and it doesn't look like previous did neither. I am about to fit new half rad, fmic and themostat, but looks like I'll have to invest in more 😀😓
