This Post Shows The Start Of Modyfying Of My POWER STARLET! B)
I Picked It Up I August 07, Just Before I Started To Learn To Drive, Started To Change Little Bits:
  • De-Badge On Front
  • TRD Badge On Boot Lid
  • Xenon Headlight Bulbs
  • Air Filter
Just After I Picked Her Up!
Once The Xenon Bulbs Were Fitted And The Badge Had Been Taken Off, I Fitted An Air Filter.
Standard Filter
The Air Filter:
Air Filter Fitted:
Thats It For The Moment Folks! Keep An Eye On This Post As I Will Be Updating It With All The Mods I Have Done! Hope You Like! :)
The Next Stage Of Modding My Starlet Was To Install:
  • 7" Touchscreen DVD Headunit By Eanon
  • 1000watt 6x9 speakers By TheLoudest.Com
  • 1000watt Sub Woofer By Phat
  • 1500watt Amplifier By TheLodest.Com
I Had To Remove The Standard Stereo Shown Below
I Then Set About Removing The Standard Unit...
And Installing The New Headunit!
Right, The Next Stage Was To Get Rid Of The Side Bump Strips!
Hot Soapy Water To Get Them Off, And To Get That Nasty Glue Off I Used Tar & Glue Remover (Special Car Valeters Stuff!)
As You Can see I Have Also Fitted Clear Front Indicators!
The Next Mods I Completed Were Putting On Some 14" Basel Alloy Wheels I Picked Up 2nd Hand, Just Had To Put New Tires On! Putting Clear Side Repeaters On. The Wheels Make Such A Difference!
Can You Spot The Difference Between The Picture Above And The One Below?
Scroll Down To Find Out!
New Import Sized Number Plates!
Decided To Get My Engine Steam Cleaned Yesterday. Did Have My Doubts About Electricals Etc Getting Wet But Turned Out Fine!
Still Need To Polish The Cam Cover! :)
I attempted to give my engine bay a good clean earlier think its the first clean its ever had under the bonnet looks a lil better tho just so many rust lookin brown bits tho :s
Turns out my induction kits gone n began to rust to.... :p
Did gettin it steamed make a lot of difference?
Before the steam was applied, the traffic dirt muc off spray was sprayed on, which loosens all the gunk off.
So when the steam is applied it rinses it all off with ease!
It was then sprayed with a liquid that polishes up all of the black parts and make them look shiny!
I found that it did clean out the bay pretty well, for 5 quid was definatley worth it!
cant believe you didnt put a bag over the airfilter when you steam cleaned it :p
I'd be more worried about covering the distrubutor cap and spark leads around the cam cover!!
