Been having problems with my idle on my glanza recently.
Its all fine when i start up from cold and as the engine warms up the revs drop under 1k,
Worst time is when im in traffic ill move off slowly the idle will be on 900rpm and once im stationary it hang for abit then drop all the way to 600-700rpm.
Also when the fan kicks in the engine will shake and struggle to pick up the revs.
What can be the problem?
Ive had this problem for almost a year but mostly happens when the waethers are hot.
Checked my ect sensor checked for air leaks. Changed the idle control valve still the same
Try adjusting the idle screw on the inlet
Ive already done that mate no difference,
It just increases the idle way high. Itll sit at around 1200,
My Glanza has the same problem. Worst after a fast run, if I stop for a few minutes and then re start the car it will really struggle to idle. Weirdest bit with mine is that with the headlights turned on the revs actually pick up a bit lol
