mr_K Posted May 28, 2016 Share Posted May 28, 2016 Been having problems with my idle on my glanza recently.Its all fine when i start up from cold and as the engine warms up the revs drop under 1k,Worst time is when im in traffic ill move off slowly the idle will be on 900rpm and once im stationary it hang for abit then drop all the way to 600-700rpm.Also when the fan kicks in the engine will shake and struggle to pick up the revs.What can be the problem?Ive had this problem for almost a year but mostly happens when the waethers are hot.Checked my ect sensor checked for air leaks. Changed the idle control valve still the same Quote Link to post Share on other sites
Whitenoize Posted May 28, 2016 Share Posted May 28, 2016 Try adjusting the idle screw on the inlet Quote Link to post Share on other sites
mr_K Posted May 28, 2016 Author Share Posted May 28, 2016 Try adjusting the idle screw on the inletIve already done that mate no difference,It just increases the idle way high. Itll sit at around 1200, Quote Link to post Share on other sites
Whitenoize Posted May 28, 2016 Share Posted May 28, 2016 Did you let it warm up before you adjusted it ? It's a strange one as you seem to have checked or changed everything that would cause it Quote Link to post Share on other sites
Flynn Posted May 28, 2016 Share Posted May 28, 2016 My Glanza has the same problem. Worst after a fast run, if I stop for a few minutes and then re start the car it will really struggle to idle. Weirdest bit with mine is that with the headlights turned on the revs actually pick up a bit lol Quote Link to post Share on other sites
daniel_g Posted May 28, 2016 Share Posted May 28, 2016 This pretty much solved my starlets idle issues. Get an intermittant hunt but apart from that it sits around 1k 95% of the time. Quote Link to post Share on other sites
mr_K Posted May 29, 2016 Author Share Posted May 29, 2016 https://youtu.be/KikW0RW_tbsCheck the video out,Its not as bad on the video but in traffic itll drop very low. Quote Link to post Share on other sites
