triple j Posted June 11, 2016 Posted June 11, 2016 Am running ct9 on stock ECU for now, but to help with boost creep I blocked off the high/low nipple on the actuator and u will need a good boost controller to bring the boost up to where u want it, am using an apexi avcr and its doing it's job very well on stock ct9(untouched wastegate). Quote
5e colin Posted June 11, 2016 Posted June 11, 2016 get a sledgehammer and smash that sh#t turbo to pieces your better of drilling a hole in the manifold Quote
triple j Posted June 11, 2016 Author Posted June 11, 2016 I would have to agree with u there lad, am just running it until I pass nct then I will stick on the td04, it's just a dead handy way to help boost creep on the little ct9. Quote
triple j Posted June 11, 2016 Author Posted June 11, 2016 Will still creep surely, when u block the pipe u are on low boost I was seeing 0.3, find a sweet spot with the boost controller(allow for a little creep) and your done, a good boost controller should bring on the boost a little faster also, it stopped me hitting fuel cut on wot it might help someone else, a ported waste gate would be a bonus this only takes 2min. Quote
Ollieh17 Posted June 11, 2016 Posted June 11, 2016 It helps yeh as many people have done but allowing a bit for creep isnt a cure. The extra boost will be slower and less consisent as its creeping. Quote
triple j Posted June 11, 2016 Author Posted June 11, 2016 This way has stopped me from hitting fuel cut without porting the waste gate, most setups will boost creep depending on conditions. Quote
5e colin Posted June 11, 2016 Posted June 11, 2016 This way has stopped me from hitting fuel cut without porting the waste gate, most setups will boost creep depending on conditions. thats what fcd are for Quote
triple j Posted June 11, 2016 Author Posted June 11, 2016 I wouldn't put one of them yoaks near my car, its staying stock until nct then I will run td04 and ecu the same as my last setup. Quote
patman Posted June 11, 2016 Posted June 11, 2016 I'm still confused here to what only takes 2 mins here and a simple cure Quote
