1998 Toyota Glanza V 300.9bhp 040 White.
Year:1998
Model:Glanza V
Tax: NA
MOT: MAR 2017
Mileage: 171k shell 15k forged engine
This is a truly reluctant sale and I really don't want to do this but a new member in the family forces this sale! I have owned this car for a little under 5 years and it has been a perfect car, I have loved every second that I drive it and every second that I've spent working on it!
It has had a lot of my hard earned money gone into it hence I would like it to go to another enthusiast who will look after it like I have or better.
The car is only advertised on UKSO, I'll see how it goes on here and if I have no luck I'll branch out the all the others in a few weeks. I'm in no rush to sell!
Build thread:
http://www.ukstarletowners.com/topic/66350-sefton-ep91s-300hp-98-spec-glanza/
The shell has done 171k mix of miles and km
The Forged engine has done 15k miles (NEVER been on track)
The spec is as follows..
Engine spec:
PEC Forged 74.5mm Piston Kit With Rings And Pins
PEC 4EFTE Forged Con-Rod Kit With ARP Rod Bolts
Athena 1.2mm Uprated Metal Head gasket
ARP 2000 Uprated Headbolt Kit Inc New Washers
New Genuine Toyota Full Gasket Kit
New Genuine Toyota Oil Pump
OEM Water Pump With New Pulley
OEM Cambelt Kit With New Tensioners And Rollers
ACL Main Bearings Kit
ACL Big End Bearing Kit
ACL Thrust Washer Kit
Fully Machined And Polished 4EFTE Bottom End
Fully Cleaned and Rebuilt 4EFTE Cylinder Head Built To Standard Spec
Block, Head and Rocker Cover Cleaned
An-8 Race Spec Rocker Cover
New NGK Iridium Spark Plugs
New Blue Magnecore 8mm HT leads
Air Cooling/intake:
WEPR Half Size Radiator with AN6 Overflow
WEPR rear entry intercooler kit
Standard intake manifold (Thoroughly cleaned)
Apexi power intake air filter (Relocated behind grille)
Misc/Exhaust/Fuelling:
Japspeed full exhaust system (fully heat wrapped)
WEPR Ram-horn external wastegate manifold
WEPR decat pipe
WEPR screamer pipe
Tial MVS V-band wastegate
Td300 billet td04 hybrid turbo
HKS SSQV dump valve
Walbro 255lph fuel pump
TD 430cc Injectors
Standard fuel rail
SARD Fuel Pressure Regulator
Braided fuel lines
Roose Motorsport ancillary hoses
Blue vacuum hoses
Electronic's
EMB mapped by TD (1.4bar producing 300.9bhp)
ZISCO field harness
GFB G-force 2 Boost controller setup by TD
Apexi turbo timer
AEM Wideband gauge (needs bung welding in exhaust)
Oil filter adaptor plate
Swoosh oil pressure gauge (needs plumbing in)
Swoosh oil temp gauge (needs plumbing in)
Defi water temp gauge (needs completely fitting)
Smoked boost gauge
Suspension/Brakes
WMS 4pot Calipers
277mm front discs
Ferodo DS2500 front pads
Earls braided brake lines
20mm hubcentric spacers (front)
15mm hubcentric spacers (rear)
Standard rear brake setup
Lowered on lowering springs
KYB shock absorbers
Exterior
16" Rota Track R alloy wheels
Continental tyres front
Avon tyres rear
Optional duck tail spoiler (rep)
Uncut 98 spec front bumper
Laguna splitter
Optional wind deflectors
Crystal fog lights
Interior
Unknown brand short shifter
Toms gear knob
Optional 5 piece starlet mats
New gear gator
3" shifter extender
Clarion DVD heat unit
Alpine speakers (front)
Pioneer Carrozzeria speakers (rear)
96 spec front seats
98 spec interior (not front seats)
3 pod a pillar trim
Indiglo dials
This car is the perfect car for someone who wishes for big power and small amount of work to get it 100%.
I was on the lookout for a LSD but had no luck sourcing one unfortunately! So this is the first thing I would recommend to the buyer as you will see exceptional gains with how the car performs, plus you will be able to use all of the power available.
I have serviced the car every 4K miles without fail and it will be serviced for the new owner before collection, I have always used good quality oil usually Fuchs oil or millers and always genuine Toyota oil filters.
The brake fluid was replaced when the WMS kit was installed no more than 7k ago, Toyota DOT5.1 brake fluid was used so the new owner can be assured that this has been covered.
The cleanliness of the car has always been on the top of my list, the car goes for a detail every month by a very good friend of mine and Is also cleaned once a week by myself using only good quality products, usually chemical guys.
The body work, the car has a small amount of rust on the passenger side and drivers side rear arches which I had quoted to be done by a professional body shop at £100 a side, it's surface rust and was on my to do list but never got round to getting them done, and some small stone chips that should be expected from a 18 year old car, This will be reflected in the price so please do not try to get it lower on the basis of this.
I have receipts for all the work that has been carried out on the car all in a folder which will obviously be included in the sale! You will also get a full set of TRD engine mounts and new set of front ball joints of which I had started to collect to do a rebush.
Photos:
0DD72885-66A1-4091-ACF7-9C5F6709CF28_zps
CF53C313-D7D7-43C0-8274-67CB38F7E5CB_zps
CDE839C6-F366-4104-ABDB-120B7C854D72_zps
Price: £6000, as most people can appreciate to get these cars to this kind of power etc takes ALOT of money, more than double the asking price so please no low ballers. All silly offers will be ignored and sensible offers will be listened to!
ALL!! road tests will be carried out by myself unless proof of insurance is produced, this will not be waithered! I will ask!
Call/text Steven on 07581093720 only before 10pm or PM me anytime and I will reply within 24 hours.
40 quid lsd from a Bzr levin and just throw it into the gearbox. Problem solved mate.
Not if you just throw it at it 😂 Belter car mate if i hadnt of bought mine a month ago id of had it. Cheap at 6k for the spec. I paid 5 and isnt even forged!
Thanks for the kind words appreciate it :)
Can't believe it's up for sale dude .... Congrats on your apprentice
Glwts buddy, a real stunner
I can't believe it either but needs must unfortunately, I'm sure I'll be back in a few years but for now its only right to get somthing abit more practical and family orientated. Thanks for the kind words!
  • 3 weeks later...
