Jakub k Posted June 14, 2016 Posted June 14, 2016 Might be getting 15x7 (front) and 15x8 (rear) et 36 and et 30 with 195/45/15 tires? Will they rub with standard shocks on 40mm springs??? Quote
daniel_g Posted June 14, 2016 Posted June 14, 2016 Front should be fine, rear will most likely scrub on bumps etc unless the rear suspension is solid and youve got an adjustable panhard rod setup. Quote
MARC MOSS Posted June 14, 2016 Posted June 14, 2016 I'd go with the wider lower offset at the front for a wider track... Looks boss as well Quote
