Hi all,
I think this thread should also be in the suspension/chassis thread.
Need your help with some diagnostic. There's clicking and clattering noises primarily coming from the passenger side of my EP91. I think there's two distinct noise that can be heard. 1st is clattering which I know is from the top mounts. 2nd is a clicking from maybe the passenger front wheel.
Could anyone else suggest things I should also look at?
OB
Edited by Tanasen
If the clicking is happening when you've got full lock on, you've got a knackered CV joint.
No, going straight forward. Just clicks every now and then.
The clicking could be the dust shield behind the disc, mine started doing it until I bent it out slightly
Hmm, I recently just changed the discs and pads so is there a possibility that with the new disc being slightly thicker its fouling on the dust shield? Although this only happens on the one side. Summer is here so I have been recently having my windows down more and noticing these noises. I'm unsure whether the clicking is prior or after the brake change.
You had new front tires lol?
Bought the car a little over a month ago. Couldn't tell you how long ago it was changed.
Thats a no then.
Was just because you had done the brakes incase you had replaced your tires as well maybe would be a stone in your tire.
And yes people have not known that before.
Thats a no then.
Will take the wheel off and just do another check sometime in the evening this week. May put a some paint on the caliper whilst I'm at it.
Pictures from the change:
13516331_607730722725082_166626495882106
13590467_607650072733147_16418934328340013529242_607650089399812_571700389624643
13600101_607650122733142_371993548592209
13438981_607650146066473_339687379840089
Good news. On the drive to work this morning there were no clicking noise. Will keep an ear out for that.
For the clattering noise anyone know where I can get some top mounts for the front?
Just a thought, could it be the wheel catching on the caliper at all?
I fitted some WMS 110% discs and due to the extra width, it'd pushed the caliper out far enough that it was touching the backs of my spokes ever so slightly.
Checked it and it's looking pretty dayum fineeee! :)
Just out of curiousity. Is the clicking after you've been hearing happening after getting the brakes hot? Usually the pad retaining clips can catch on the disc.
Literally put the brake dics/pads on. Took the car 5 minutes down to the petrol station and back with my windows down. That was when I noticed the noise. Had the windows down on the way to work and it seems fine now. Strange.
