Idle very low, cutting out
My glanza is having really bad low idle problems,
In traffic when im stationary the cooling fan will kick on and then suddenly my revs bounce all the way down to 100rpm and back upto 800rpm, it evens stalls when its sitting in slow moving traffic.
I dont know whats causing this problem,
Ive uploaded a video and have a look at how low the idle drops.
I purposly switched on all electronics so that you get an idea of it.
The handbrake light dims and as i rev the engine i can see it getting brighter and back to dim when idle drops.
Can it be a battery,alternator problem or a idle control valve?
https://youtu.be/PDZyjsEx4zE
Thanks
Edited by mr_K
Seems like alternator or could be a bad earth,chek battery with a meter to see if u are getting a good charge and maybe clean your earths.
Where are the main earths on the glanza's?
I know ones on the iacv.
This may not of caused the issue but I remember one time I forgot to put the pipe on from the inlet manifold to pcv valve and it done what's happening in the video
Im running a race rocker cover also all ends are blocked on the intake manifold.
