H_D Posted July 27, 2016 Posted July 27, 2016 I need to change the steering rack on a mates EP91 V,has anyone done this before? any help or guides will be much appreciated as always. Thanks. Quote
jayc-glanza17 Posted July 27, 2016 Posted July 27, 2016 Why you changing the rack?But theirs two clamps which have 4 bolts/nuts just above lower gearbox mount.And then theirs the 14mm nut which holds the column to the rack.. Quote
gorganl2000 Posted July 28, 2016 Posted July 28, 2016 (edited) i assisted my mechanic with this process on my ep91 a few years ago....i can recall it being a pain....not overly difficult, but just tediousits best to do it on a ramp and you may need assistance to make it easier...from memory, remove the wheels (may give you more space to work with) ,,there is a bolt at the bottom of the steering rack inside the car...slacken that (its splined off to the steering rack), rod ends have to be disconnected from the hubs, i think there were two "u" type clamps holding it to the firewall which those have to be removed...there there is the section just be the firewall where it enters the car...disconnect the two vaccum tubes on the rack...disconnect the power steering hoses,,,etc before you remove it make sure to straighten the steering wheel as this will help you later when trying to align the car wheels and steering...IF you are getting an EXACT ep91 rack, after you remove the old one, just try to match it up against the new rack to make sure the rod is the same distance on BOTH sides on both racks...basically then install the new rack, rod ends, vaccum tubes, PS hoses, etc hopefully your steering is still in the "centre" spot you left it fill the PS reservoir and bleed the system the car will need a wheel alignment that's just the few things i can remember....i'm sure i left out somethings as this was a long time ago Edited July 28, 2016 by gorganl2000 Quote
H_D Posted July 28, 2016 Author Posted July 28, 2016 Thanks Gorgan. I assumed this would be the case but just wanted to know what I was getting myself into before I agreed to do it Quote
