sam_glanza_v Posted August 16, 2016 Posted August 16, 2016 Hi guys planning on putting an air filter relocation on shortly to get rid of the horribly long route stock one. Just wondering what everyone has done with the crank case breather hose that goes into the intake? I know the rocker cover takes one of those little filters aswell just not sure what size? 😊 Cheers guys! Quote
aleximport25 Posted August 16, 2016 Posted August 16, 2016 i just blanked the vac port on the inlet mani :-) i cant remember the diameter of the breather on the rocker as i went down the route of AN fittings Quote
patman Posted August 16, 2016 Posted August 16, 2016 i just blanked the vac port on the inlet mani :-) i cant remember the diameter of the breather on the rocker as i went down the route of AN fittings12mm breather filter mate 👍🏻 Quote
gazza g Posted August 16, 2016 Posted August 16, 2016 12mm breather filter mate whats 3mm between friends Quote
patman Posted August 16, 2016 Posted August 16, 2016 (edited) True mate I know 15mm will be ok with jubilee clip, I actually used a 11mm breather filter on mine :-) Edited August 16, 2016 by patman Quote
sam_glanza_v Posted August 21, 2016 Author Posted August 21, 2016 i just blanked the vac port on the inlet mani :-) i cant remember the diameter of the breather on the rocker as i went down the route of AN fittingsDoes that not affect the idle mate or is it okay? I take it it's running okay for you? What do people do with the actual pipe coming up from the crankcase? Quote
aleximport25 Posted August 22, 2016 Posted August 22, 2016 It's always been fine buddy, if it was venting to atmosphere it would idle high, which pipe do you mean ? Quote
