Hi guys planning on putting an air filter relocation on shortly to get rid of the horribly long route stock one. Just wondering what everyone has done with the crank case breather hose that goes into the intake? I know the rocker cover takes one of those little filters aswell just not sure what size? 😊
Cheers guys!
i just blanked the vac port on the inlet mani :-) i cant remember the diameter of the breather on the rocker as i went down the route of AN fittings
12mm breather filter mate 👍🏻
True mate I know 15mm will be ok with jubilee clip, I actually used a 11mm breather filter on mine :-)
Edited by patman
Does that not affect the idle mate or is it okay? I take it it's running okay for you? What do people do with the actual pipe coming up from the crankcase?
