EP70-PT Posted September 7, 2016 Posted September 7, 2016 (edited) Will these fit or will I just have to take them off? Installing glanza brakes on my N/A soon! Edited September 7, 2016 by EP70-PT Quote
morgey Posted September 8, 2016 Posted September 8, 2016 They are fitted with before the stubaxle is pressed into the bearing stopping it from being removed but You can unbolt and cut through it or in most cases it will have rusted so much it can be pulled apart. Quote
EP70-PT Posted September 9, 2016 Author Posted September 9, 2016 I cut it mate just like you said, not a sign of rust on them Quote
jeffrosie Posted September 20, 2016 Posted September 20, 2016 No need to cut as Glanza discs will fit fine in there with slight bending of the cover. Quote
EP70-PT Posted September 20, 2016 Author Posted September 20, 2016 I removed mine a while ago ahah Quote
