Mine popped out of 5th a few times on the way to and back from jae
Must be some kind of common problem hopefully we can find what's callusing it
Check your oil level, any excess movement in the engine mounts?
All engine mounts are solid Polly bushed so no movement did give the box an oil change recently was fine will give it a check again
If thats the case, its more than likely a worn selector/gear itself. A worn synchro will only make changes a little hard, not cause it to drop the gear itself.
