I have these sets of callipers, pistons are 38mm, MR2/Levin brake pads fit. But MR2 pistons are 36mm and everything else I have looked at are either bigger or smaller than mine:
I have already asked Russ on here, he reckons mk2 n/a mr2, but only info on them is 41mm singles?
Only Toyota 38mm pistons I can find are for ST205 rear single pots, completely different design..
Asking here for anyone else with ideas, because these are pissing me off!
Deffo look like the levin, but the seal kit I bought (only one I could find on ebay) doesn't fit, dust seals far too big. Can you measure your pistons too for me, then I will know if the seals will fit?
Piston measurement are on caliber, zoom picture. 36mm on MR2 and 38mm on Levin.
Hmm seem to be Levin then, shame the Levin kit I bought doesn't fit :| I think Russ has found me the right kit with these:
http://www.ebay.co.uk/itm/A-B-S-Repair-Kit-brake-caliper-Toyota-Carina-E-1992-1997-/131927540820?fits=Model%3ACarina&hash=item1eb77e8454:g:pGoAAOSwgmJXyoXS
What is the distance between the mounting bolt holes, center to centre? (where the bolt to the strut)
I will check when Im home! P.s. sell me a set of you sexy brakes <3
More than happy to - they are on the shelf for once! :D:D SW20 (Mk2 MR2) front mounting bolts are 149.0mm apart, not the same as Starlet.
PM'd about them and thanks, I'll give it a look tonight, appreciated.
