DamianGemmell Posted September 15, 2016 Share Posted September 15, 2016 I'm finally getting around to rebuilding my 5e with my 4etfe pistons but realised yesteday that the gudgeons are pressed in and not the easy kind. I've read into it a bit and some people recommended using some heat to remove them and some say just to use a press on its own. So my question is who here has done this job themselves and how did you do it?Also when putting the gudgeons back in do you just press them again or do you heat the small end of the conrod so the pin will drop in?Any advise would be much appreciated. Quote Link to post Share on other sites
5e colin Posted September 15, 2016 Share Posted September 15, 2016 no need to heat them up just pres them out sacrifice a socket and cut the mid section out off it and leave some on the outside ( tight fit ) so the gudgeon pin just slides into the socket and the 2 legs that remain support the piston right around the gudgeon pin hole i have never cracked pistons this way refitting them can be done cold to but oil them up so they slide pic to follow Quote Link to post Share on other sites
DamianGemmell Posted September 16, 2016 Author Share Posted September 16, 2016 Cheers man. I think I know what you mean with the socket but a picture would be great. I should be able to have a go off pressing them on Monday or tuesday. And then the build can begin at last. Quote Link to post Share on other sites
5e colin Posted September 16, 2016 Share Posted September 16, 2016 dont have a pic in my photobucket anymore will have to go and dig out the old socket somewhere its around somewhere ha ha if i cant find it i will cut a new 1 to size for you to see Quote Link to post Share on other sites
DamianGemmell Posted September 16, 2016 Author Share Posted September 16, 2016 Mighty stuff. I'll go looking for a sacrificial socket tomorrow and have a go at shaping it. Thanks for the info. Really helpful. Quote Link to post Share on other sites
5e colin Posted September 20, 2016 Share Posted September 20, 2016 cant find the pics on my database but i did spot them in my build threads scroll down to post 203 !!! http://www.ukstarletowners.com/topic/88445-missstress-tmd/page-5 Quote Link to post Share on other sites
DamianGemmell Posted September 21, 2016 Author Share Posted September 21, 2016 That's the berries. Nice one. With a bit of luck I'll be pressing them tomorrow if the buddies work shop is quiet. Its doing my head in now just waiting to start building. Quote Link to post Share on other sites
