Hi
Could anyone help me out with timing of the cam shafts on a 4efte gt engine
I have timed the engine up with the 4e marking on the cam pully and I have timed the bottom crank pully up
But I am unsure if the cam gears are also out of time.
Because the timing has been messed with and the car is no longer starting
Really need help
Cheers guys
If you have timed up the cam pulley with the marking at 4E & the crank pulley at 10 degrees BTDC. With all this just make sure cylinder 1 is at TDC. Then for the actual cams just make sure the the 2 dots on each of the cams are in line together.
It should then be fully timed up.
