Tilteduk Posted September 18, 2016 Share Posted September 18, 2016 Hi guys and girls just got a glanza and its started dropping revs when I'm at a constant speed around 2500-3000rpm or if I'm sat still and hold the revs there also it's like it cuts out then starts again...no one knows what it is but I'm hoping one of you guys will??? Quote Link to post Share on other sites
5e colin Posted September 18, 2016 Share Posted September 18, 2016 (edited) could be 1 of many things its hunting ecu temp sensor iatdistributor map tps thats where i would look/test first how hard is the hunting ?? how many rpm doos it change ?? Edited September 18, 2016 by 5e colin Quote Link to post Share on other sites
Tilteduk Posted September 18, 2016 Author Share Posted September 18, 2016 Only drops 300rpms for a sec or so Quote Link to post Share on other sites
Andy32 Posted September 28, 2016 Share Posted September 28, 2016 sorry to jump onto your thread bud but am having a similar problem.it started last week out of the blue,whilst driving the car lost power didnt really know what had happened and dismissed it.has now started doing it more regularly but totally intermittently. in any gear the car will just cut and with my foot to the floor will not pick back up until i come off the throttle and go back on then it will reaccelerate fine.today it did it so i kept my foot on accelerator to see what happens and the revs dropped all the way down to idle and the car was coasting once it reached around 1000rpm tho it started to pick back up this all happened without any lift off the throttle.like i said sorry tilted to jump on but it may help you out too mate. Quote Link to post Share on other sites
teta Posted September 28, 2016 Share Posted September 28, 2016 distributor I ll check 1st Quote Link to post Share on other sites
Andy32 Posted September 29, 2016 Share Posted September 29, 2016 just quick update. had a quiet afternoon in the garage today so went right through everything again and solved the problem,had a bad wire on the throttle position sensor.must have been an issue for a while as its not run this good for a long while,hope this helps with any future issues out there guys and girls!! Quote Link to post Share on other sites
maerijn Posted October 17, 2016 Share Posted October 17, 2016 I had the same thing and found a bad connector on the coilpack Quote Link to post Share on other sites
