EP70-PT Posted September 21, 2016 Posted September 21, 2016 (edited) Need to find a wire that has 12v when the high beams are on.. My N/A clock wiring doesn't go well with the paseo clocks,I don't have the same wiring as other people that did the conversion here for some reason... My high beam indicator is on when lights are off, off when low beam is applied and dimmed on high beamm.. Idk why it stays on when the lights are off so I need to find another source for it... Edited September 21, 2016 by EP70-PT Quote
TrisK Posted September 21, 2016 Posted September 21, 2016 Just put a relay in. A 4 pin NO (normally open) relay should do it Quote
EP70-PT Posted September 21, 2016 Author Posted September 21, 2016 Maybe my actual relay is gone too... No? Quote
Flaminsam Posted September 22, 2016 Posted September 22, 2016 The headlights have a permanent power to them if i remember right. Then it's the switch in the car that gives them an earth to turn them on. Quote
EP70-PT Posted September 22, 2016 Author Posted September 22, 2016 Problem solved, headlights ON had a switched ground, had to do a separate circuit for the HIGH BEAM on the paseo clocks... Something a bit like this:ALL GOOD NOW! Thanks guys Quote
