EP70-PT Posted September 23, 2016 Share Posted September 23, 2016 What I said... I'm tired of this sh... Even my tacho needle goes up when I turn my key without even starting the engine... Heeeelp Quote Link to post Share on other sites
nikhilkamdar12 Posted September 23, 2016 Share Posted September 23, 2016 Check all your grounds. Stange things can happen if you have poor grounds!! Quote Link to post Share on other sites
EP70-PT Posted September 23, 2016 Author Share Posted September 23, 2016 Not the grounds.... I should maybe say that my battery is low (7v), can it be a relay?? Quote Link to post Share on other sites
Pete_A Posted September 23, 2016 Share Posted September 23, 2016 Do your lights work with indicators? Lights r a fuse, indicators a relay, so bad earth under the bonnet? Quote Link to post Share on other sites
EP70-PT Posted September 23, 2016 Author Share Posted September 23, 2016 They won't work with indicators...the earths are fine.. Quote Link to post Share on other sites
EP70-PT Posted September 24, 2016 Author Share Posted September 24, 2016 Solved Quote Link to post Share on other sites
