trying to fit an apexi at2 unit to my ep82 (second hand unit).
spliced the white/red wire from ignition to red on unit
spliced the blue/red wire from the ignition to blue on unit
spliced the black/white wire from the ignition to the green on unit
spliced the yellow/blue from handbrake to the grey on unit
earthed the black
when i switch the ignition off the engine cuts out but the electronics stay on for the timed duration and then go off.
pretty sure i got wires right as i cont-tested them before hooking up but havent managed to find an official Apexi AT2 wiring diagram.
any ideas chaps or just faulty TT?
cheers
There are two ignition wires one being accessories and one being live even while cranking. It's the one while cranking you want not acc
