Year: 1996
Model: glanza v
Tax: n/a
MOT: Feb
MileagENGINE
Wiseco 74.5mm Pistons
Scat Rods
ACL Bearings
ARP headbolts
1.2mm Athena gasket
Wepr evo mani and down pipe
(Heat wrapped) with matching turbo blanket
Tial external wastgate
Braided oil line
Td04 hybrid turbo (tuning developments)
Tuning developments 430cc injectors
Tuning developments fpr
Tuning developments lightened flywheel.
Fensport lightened crank pulley
Custom exhaust
Ramair foam filter
Rw Development Oil catch tank
Racespec rocker cover
Civic rad and slimline fan
Toyosports fmic
MAGNECORE HT 8mm Plug leads
NGK Range 8 Iridium plugs
Turbosmart kompact bov
WALBRO 255 L/H Fuel Pump
DRIVETRAIN
Quaffie lsd
Competition stage 4 clutch kit
HANDLING/CHASSIS
Bc racing coilovers
Enkei compe 15x7 with new ns2r tyres
OEM Rear Strut
c-pillar bar
Whiteline 22mm front arb
Whiteline panhard rod
Whiteline adjustable rear arb
Whiteline ALK
Full powerflex poly bush kit
(Every single bush replaced)
New ball joints and track rods
braided brake lines with blue racing fluid
Abs delete
Power steering removed
STYLING/BODY
Genuine Toyota optional extra lip kit front and rear
Genuine ducktail
98 rear lights
Carbon wrapped roof and bonnet
INTERIOR.
Recaro evo8 seats
Gizzmo boost controller
Quick shifter with gear shift extender
Takata harness
Turbo timer
Genuine Toyota mats
Speedo converted to mph
There has been no expense spared on this car but as much as I love it I need something that's not track based like this is. Will be In For mapping soon as I'm changing the ecu from emb to emu. Made 305bhp on emb at 1.4 looking for 6.5k for the car
Probably missed quite a few things. All whiteline and powerflex parts are brand new
Price:
6500
Contact Details:
Inbox me for more info
Pictures:post-14174-0-37454000-1477484265_thumb.jpost-14174-0-90218800-1477484293.jpgpost-14174-0-15686000-1477484334_thumb.jpost-14174-0-49304100-1477484365_thumb.jpost-14174-0-85816900-1477484385_thumb.jpost-14174-0-10066500-1477484416_thumb.jpost-14174-0-04945700-1477484433_thumb.jpost-14174-0-61901600-1477484503_thumb.jpost-14174-0-97348500-1477484536_thumb.j
Only about 60 so far. Once it's ran in it will be off for mapping again. Car was ran on emb but the gfb boost controller broke so I fitted a gizzmo one for the time being until it got fixed. Put it on the rollers on a rolling road day and it was spiking on the graph due to the boost controller and it melted a piston. Luckily nothing else was damaged. I have just spent a fortune on forging the engine again all done by one of my mates at jre racing a very well known engine builder. I'm gutted as I have spent probably more than I am asking for the car
Edited by Damienx13
whats the brakes on it mate?
Standard with abs delete, braided brake lines and blue racing fluid. Did try getting hold of wms multiple times and tried to buy other brake kits with no luck. Car still needs a bit of finishing in that department
  • 2 months later...
