X_Milch_X Posted November 2, 2016 Posted November 2, 2016 (edited) Hi All,I'm having a few issues under load ordered a replacement Dizzy from someone on here but it wasn't right. Cleaned up my Dizzy and the car was running fine but is now going into a limp mode once more. Any recommendations on a fix or what i could be looking at to remove the Dizzy from the equation.Thanks in advance. Edited November 2, 2016 by X_Milch_X Quote
X_Milch_X Posted November 2, 2016 Author Posted November 2, 2016 Knock Sensor....Knock sensor is fine... Quote
5e colin Posted November 2, 2016 Posted November 2, 2016 (edited) Either oil getting inside the dizzy or short under load???It's probly not the dizzy but a connection somewhereCould also be king or ignition lead shorting under load Edited November 2, 2016 by 5e colin Quote
X_Milch_X Posted November 2, 2016 Author Posted November 2, 2016 Either oil getting inside the dizzy or short under load???It's probly not the dizzy but a connection somewhereCould also be king or ignition lead shorting under load Cheers bud looking into shorts at the moment as when the hazards are on it goes into limp mode just like it does under load Quote
5e colin Posted November 2, 2016 Posted November 2, 2016 What codes is the diagnostics showing up? Quote
X_Milch_X Posted November 3, 2016 Author Posted November 3, 2016 What codes is the diagnostics showing up?Haven't got a reader to check, can you recommend? Quote
5e colin Posted November 3, 2016 Posted November 3, 2016 Bridge diagnostic port and count the blinks on dash Quote
X_Milch_X Posted November 17, 2016 Author Posted November 17, 2016 (edited) Thanks for the help guys, The issue seems to be an electrical fault. Currently having the loom re-wired to rectify the issue. parts replaced to far:- Dizzy- Fuel Pump - Clutch (previous clutch worn)- rocker (cover re-sealed due to an oil leak)Just seems to be multiple issues but hopefully will have the car back by the end of the month Edited November 17, 2016 by X_Milch_X Quote
