Hi,
Due to a recent prang, my indicators and horn don't work. I've little to no experience on working with electronics and don't know where to start.
When the ignition is on I can toggle the indicators or the hazard light button yet nothing happens, no interior or exterior indication. the same with the horn, press it and nothing happens.
any advice or suggestions would be greatly appreciated.
Thanks
Edited by StarletSouthampton
  • 3 weeks later...
Hi bud did you fix the problem if not check the bulbs are not blown then I would get onto checking fuses aint blown etc I live in Southampton as well could always meet and ill take a look.
Hey, finally got around to looking at the problem and it is indeed the fuse. However when I replaced it with a new fuse it blew immediately! I've taken the indicators out and the bulbs are in tact. I have removed the horn, however the wires pulled out of the connector as I did so. I tried a new fuse again with everything apart and it still blew instantly. Not sure what to do next!
