Hi guys I'm looking to break my engine in with a tf035 on it but it won't have a map or fcd & rrfpr. Just a standard ecu and bigger injectors
Can this be done without blowing it up if I get an adjustable actuator and run the lowest boost possible ? Taking it easy under 4000 rpm
Lastly would this be a bad decision to break it in on low boost and then have it mapped at .8 or .9 bar ?
Hope this makes semse and thanks in advance :)
I ran my fresh built engine in with minimal boost and pretty gentle, just using revs
Lota of info on that on here, always differing opinions though
Is it a fresh built standard engine new rings etc or forged build?
Nope won't do harm just keep eye on afr if you don't have get it before upping boost
A good wideband is on the to get list :thumbsup:
Fresh build non-forged
